How to stop the flywheel welding to crank?
#1
Posted 06 October 2010 - 01:59 PM
Last time crankworks told me to put grease on the crank tapper and flywheel, then red lock tight the nut on. Did this and it still having the same issues. if we put more time on the engine and i pulled the flywheel i know it would of ruined the crank.
So what can i do to cure this for good?
#2
Posted 06 October 2010 - 02:24 PM
#3
Posted 06 October 2010 - 07:26 PM
also do you put red loctite all over the tapper of the crank and flywheel then torque to factory specs?
the key did not break and all was tight, so i don't understand how it could even be moving to cause the problem????
#4
Posted 06 October 2010 - 10:08 PM
#5
Posted 07 October 2010 - 03:01 AM
#6
Posted 07 October 2010 - 05:18 AM
Wife's 370R Fastest true gas Pro-X Honda 4.29 in sand 4.17 in dirt 300ft on a dune chassis.
2-cycle generator and an old school Lawnboy to mow the yard!
It aint no joke if it blows blue smoke
#7
Posted 07 October 2010 - 07:13 AM
also once you lap the flywheel to the crank is it good to remove and reinstall, or should you lap the flywheel every time you reinstall it?
#8
Posted 07 October 2010 - 08:34 AM
#9
Posted 07 October 2010 - 11:19 AM
i usually just take a impact and run the nut up til it stops turning but put red lok tight and then if need removed use a lil heat!..once u lap it you should be good to go,i only lapped mine one time and ive had it off 20+ times now..
#10
Posted 07 October 2010 - 01:33 PM
#11
Posted 27 April 2011 - 04:13 PM
#12
Posted 28 April 2011 - 01:33 AM
Honestly if this happens again, i simply think i'm gonna drill a couple holes in the flywheel so i can access the stator screws. This way if i ever need to split the cases again i could do so with out removing the flywheel, and let that sucker weld on there solid.
I wonder if anyone has ever built a billet crank with a forged stator web? that way the stator shaft is forged and wouldn't weld to the flywheel... Was another thought I had as i'm tired of ruining expensive cranks.
#13
Posted 28 April 2011 - 09:22 AM
#14
Posted 05 December 2011 - 11:14 AM
A day on the dyno and 10 minues of dune time max on the engine and the flywheel was already welded on.... anyone else have any ideas or advice?
#15
Posted 05 December 2011 - 01:34 PM
If it is lapped correctly and torqued down after a heat cycle, there would be such a small area for loctite to be it's pointless to use.
On the other hand, I wonder if the loc-tite is what is "welding" it together.
#16
Posted 05 December 2011 - 01:48 PM
And by when i say welding itself i mean when i pull the flyweel off it actually pulls chunks of metal off the crank as it is "welded" to the flywheel. i'm guessing it is electrolysis. sorta like when you put lead weights on aluminum wheels overtime something creates a bond between the two from two different types of metal.
I can't possibly be the only person with this issue, as i have talked with several builders and crankworks and they have all seen it. however everyone's recommendations have not worked and this has happened year after year after year!
#17
Posted 05 December 2011 - 02:40 PM
#18
Posted 05 December 2011 - 03:46 PM
Its gotta be something with the two different types of metals. Crankworks should start making flywheel hubs out of the same material as their cranks so it isn't an issue.
#19
Posted 05 December 2011 - 04:07 PM
#20
Posted 06 December 2011 - 05:17 AM
What stator cover are you running? It seems like the billet stator covers would hold more heat in than the oem plastic ones.
also........
Are the drag pipes on the left or right? I would think having the pipes on the left would block air to the cover and keep more heat in that area.
I may be out in left field so take it with a grain of salt.
Register Now!
Help
