yfz 450 not cranking fast after stroked and 14 to 1
#1
Posted 04 March 2010 - 08:49 AM
#2
Posted 04 March 2010 - 08:52 AM
#4
Posted 04 March 2010 - 06:45 PM
dylan, on 04 March 2010 - 08:52 AM, said:
I am the lucky one with the starter not cranking fast. Checked valve clearences intake=.0055 exhaust=.0095. Timing set correctly. Decompression pin seams to function properly,opens valve .016. Had someone suggest a kick starter,is this what I need? Any suggestion?Leaving in a week for week long trip.
#5
Posted 04 March 2010 - 07:47 PM
#6
Posted 04 March 2010 - 08:36 PM
dylan, on 04 March 2010 - 07:47 PM, said:
Are you saying to thighten the valve on the decompresion side? Timing seems to be perfect. I am also running a 45mm packard lectron ,fci intake,dynatek programable cdi,resitor kit,jsr pipe big can and have a inmotion drag pipe to play with. Bike will start if battery charger is on for atleast 30mins and run great. nice puff of black smoke when you wick the throttle. seems to wander alittle when returning to idle. maybe to lean on the bottom? as far as the crank all i was told is that it had a 4 mill hotrods crank will try and find out. also keep in mind have 200 cca battery. stock is only 85 cca. Thanks!
#7
Posted 04 March 2010 - 08:55 PM
#8
Posted 05 March 2010 - 12:10 AM
#9
Posted 05 March 2010 - 06:24 AM
smcla1977, on 04 March 2010 - 08:36 PM, said:
yeah i was saying you could tighten the valve on the decomp side a little. sounds like you got it fixed. I'm running a ltr450 battery, not sure the cca, but the starter was doing the same thing you described. only way it would start was to leave a battery charger hooked up & crank up the amps.
sounds like with your mods that bike should be quick, good luck.
btw, the hotrod crank is a shortrod 66.3mm stroke
#10
Posted 05 March 2010 - 07:40 AM
#12
Posted 06 March 2010 - 04:39 AM
#13
Posted 07 March 2010 - 12:42 PM
#15
Posted 07 March 2010 - 03:38 PM
Register Now!
Help
