ATV Drag Racers: Balancing OEM banshee Flywheel? Who does it? - ATV Drag Racers
Jump to content
Page 1 of 1
  • You cannot start a new topic
  • You cannot reply to this topic
Balancing OEM banshee Flywheel? Who does it? Is it needed?
#1 User is offline   Mailman
  • 1/4 THROTTLE
  • PipPip
  • View gallery
  • Group: MEMBERS
  • Gender:Male
  • Interests:Duning and hill shooting on a shee, motocross on 2 wheeler
Posted 29 July 2009 - 10:44 AM
Any of you guys ever check the balance of your oem banshee flywheel?
If so, then was it off much?
The inside of mine got a little beat up from the stator bolts coming loose so I thought it might be a good idea to have it checked.
Who does balancing?
Mailman
Just a little more hp and I should be set.
0
#2 User is offline   dirtracer
  • Idle
  • Pip
  • Group: MEMBERS
Posted 18 January 2012 - 12:08 AM
I can balance your flywheel. some engine they are off badly.
0
#3 User is online   pipe-ster
  • Custom Pipe Builder!
  • Group: Site Advertiser!
  • Gender:Male
Posted 18 January 2012 - 08:31 AM
Who does balancing?
Mailman
yes. Crank works in Az or Revco in Ca
0
#4 User is offline   gpr
  • Idle
  • Pip
  • Group: MEMBERS
Posted 18 January 2012 - 01:46 PM
Years ago i asked crank works about balancing a flywheel, and they told me they didn't do that. Did they start recently?
0
#5 User is offline   Mailman
  • 1/4 THROTTLE
  • PipPip
  • View gallery
  • Group: MEMBERS
  • Gender:Male
Posted 18 January 2012 - 03:18 PM
I went down to Crankworks last year and I think Phil said that they can balance the banshee flywheels but it is really not worth it. He said they are usually close.
This post is a couple years old but the topic is still valid. I ended up using another flywheel in this situation.
For the record, I talked to someone who said they would try different banshee flywheels on the dyno and some worked much better than others. I never got a chance to try this for myself. Matt, have you ever tried swapping flywheels to see any gains in hp?
0
#6 User is online   pipe-ster
  • Gender:Male
Posted 18 January 2012 - 04:08 PM
yes, haven't seen an hp or tq gain from a balanced to a non balanced flywheel but I'm testing on a balanced engine.
0
#7 User is offline   J-Madd
  • Idle
  • Pip
  • Group: MEMBERS
Posted 24 January 2012 - 11:47 AM
Aren't they balanced at the factory on their respective OEM crank? It seems all of them would be off a little once you change cranks if that is the case. Wouldn't they have to be installed on the crank to be balanced, not just balanced alone?
0
#8 User is online   pipe-ster
  • Gender:Male
Posted 31 January 2012 - 08:48 AM
Banshee flywheels are balanced to 0. They arent used to balance the crank such as on a big block chevy. Usually they are off from the factory but I dont thing there is a huge HP gain in balancing them just easier on the rest of the parts. :twocents:
0
Share this topic:
Page 1 of 1
1 User(s) are reading this topic
0 members, 1 guests, 0 anonymous users
Skin and Language
Execution Stats
  • Time Now: May 18 2012 12:36 PM
