Page 1 of 1
burn piston
#1
Posted 24 January 2012 - 06:08 PM
we took the head out of my friend banshee and he got a hole on top of the piston,,,bad gaz,,detonation ,,lean ??? etc etc thankss,by the way is a mild port banshee ,4 degree timing,stock carb,360 jet,30 pilot,4 clip..045 squish,135 comp ,sst pipes,k&n filter,,,,thanksss
#2
Posted 24 January 2012 - 06:47 PM
could be a combination of all...at 135 comp 91 pump im assuming is what he is burning in it and shouldnt cause detonation as far as bad gas, pump gas will last for months, 4 deg would be right on timing for his set up, I would be leaning towards a lean condition to cause the hole, elevation and or temp.
Dirtworx Midrange Port 350
#3
Posted 25 January 2012 - 03:36 AM
Fmf SST pipes have a super tight reducer in stinger, i believe its 15-16 mm diameter for about an inch. that too will create alot of heat on piston top.
#4
Posted 25 January 2012 - 05:23 AM
My vote goes to bad gas.
Just a little more hp and I should be set.
#5
Posted 25 January 2012 - 10:24 AM
did you bother to run a leak down test before you pulled the head off?
#7
Posted 25 January 2012 - 03:44 PM
Something no one else has asked..... how cold was it outside when it holed the piston?
The main "SHOULD" be ok, if it holed the piston puling a small load like up an incline, then it may need the needles changed or adjusted.
slow 421 dragger, duner banshee, 310R duner
Wife's 370R Fastest true gas Pro-X Honda 4.29 in sand 4.17 in dirt 300ft on a dune chassis.
2-cycle generator and an old school Lawnboy to mow the yard!
It aint no joke if it blows blue smoke
#8
Posted 26 January 2012 - 01:11 PM
good idea i'll chek for air leak somewhere and the temperature was like -20 outside it was very cold that day thanksss
Share this topic:
Page 1 of 1
Register Now!
Help
