banshee stock port duration
#1
Posted 09 December 2011 - 06:04 PM
#2
Posted 09 December 2011 - 10:12 PM
all you really need to know is they suck. whip out the degree wheel and just measure a set. the base gasket thickness can vary them as wel as tolerances in piston, rod and cylinder,
#3
Posted 12 December 2011 - 06:34 AM
#4
Posted 14 December 2011 - 01:33 PM
#5
Posted 14 December 2011 - 06:26 PM
Exhaust - 185*
Trans - 120*
Boost - 114*
#6
Posted 14 December 2011 - 07:04 PM
#7
Posted 14 December 2011 - 07:49 PM
#8
Posted 17 December 2011 - 08:27 AM
#9
Posted 19 December 2011 - 03:42 PM
Not really as cut and dried as a simple chart....
There's a software program that was floating around that would do the calc's for you if you input the proper information.
I've got a spreadsheet setup to do my calc's....
Regards,
Rog
#10
Posted 19 December 2011 - 08:44 PM
#11
Posted 20 December 2011 - 03:20 PM
#12
Posted 20 December 2011 - 10:53 PM
#13
Posted 21 December 2011 - 06:24 PM
#14
Posted 11 January 2012 - 11:11 PM
if you have already done a bucnh of motors and they all scream and work great why do you need to know stock port durations? if you only do ss stock rod 350 banshee motors then you dont really need the stock measurements?.
seems the stock port durations are up there a few posts so what else do you need to know? the programs are really needed for that reason i love to be able to do an entire motor and degree it all in. but its not going to happen every time.. and also you can use the program to figure if an existing port job will work with differnt rod/ stroke combo's and what they may have efect wise on squish, deck height and other factors..
Register Now!
Help
