ATV Drag Racers: banshee 10mm jetting - ATV Drag Racers
Jump to content
Page 1 of 1
  • You cannot start a new topic
  • You cannot reply to this topic
#1 User is offline   jmbanshee
  • Idle
  • Pip
  • Group: MEMBERS
Posted 03 December 2011 - 03:04 PM
i will like to know where to start on the jetting for my motor,,,,it'a banshee 10mm stealth vito's cylinder 465cc,68mm bore,ported,22cc head,200*exaust,130*transfer,pump gaz,4 * timing ,the carb are dual 35mm pwk air striker,k&n filter in open air box,, between 0-500 sea level,thanksss jm ,,,,,,,,,,,,,,the needle is a DEK did i have to change it to a CEL ???? thanksssjm very appreciated
0
#2 User is offline   jmbanshee
  • Idle
  • Pip
  • Group: MEMBERS
Posted 03 December 2011 - 03:19 PM
forgot to mention i got shearer inframe small bore pipes
0
#3 User is offline   jmbanshee
  • Idle
  • Pip
  • Group: MEMBERS
Posted 08 December 2011 - 06:33 PM
it's look like no one run those cylinder ????
0
#4 User is offline   badassbanshee479
  • OFFICIAL WELCOME WAGON
  • PipPipPipPipPip
  • Group: MEMBERS
  • Gender:Male
  • Interests:anything with wheels or a skirt!!!
Posted 09 December 2011 - 06:49 PM
yes cel needle, 160-170 main 50-60 pilot should be a good starting point..... just make small adjustments and keep an eye on your plugs
Titan 10mill super cub runnin on the booze!
Is this where I list all my worthless bolt ons?
0
#5 User is offline   Radar
  • Pin it to win it
  • Group: Site Staff!
  • Gender:Male
  • Interests:Hunting,ridin, Lake of the Ozarks and hangin with my wife and kids
Posted 12 December 2011 - 06:42 AM
I doubt you will find many people with that combo. Cylinders with 200/130 degrees with small bore pipes may need larger mains than normal I dont know. Normally 152-165 with 35mm carbs but like Bada said it may be up near 170? 200 degrees of exhaust and 130 degree transfers with 4 degrees of timing may be a pretty pipey motor that will not like to be off very far on the jetting.
Until the sand flies.....your just blowin smoke.
0
#6 User is offline   jmbanshee
  • Idle
  • Pip
  • Group: MEMBERS
Posted 14 December 2011 - 01:27 PM
i don't have alot of experience with 10mm stroker ...you think i got to much timing for that kind of motor ??? thanksss jm
0
#7 User is offline   jmbanshee
  • Idle
  • Pip
  • Group: MEMBERS
Posted 14 December 2011 - 01:28 PM
here the best gaz pump we have it's suppose to be 94 octane,,,thanksss jm
0
#8 User is offline   badassbanshee479
  • PipPipPipPipPip
  • Group: MEMBERS
  • Gender:Male
Posted 15 December 2011 - 01:46 PM
put it on alky crank the timing up to around 6 or 7 degrees and never look back lol
0
#9 User is offline   Radar
  • Pin it to win it
  • Gender:Male
Posted 15 December 2011 - 03:31 PM
I would think 4 or 5 degrees would probably be good on gas.
0
#10 User is offline   jmbanshee
  • Idle
  • Pip
  • Group: MEMBERS
Posted 25 December 2011 - 02:56 PM
ok i leave it at 4 degree of timing thanksss
0
Share this topic:
Page 1 of 1
1 User(s) are reading this topic
0 members, 1 guests, 0 anonymous users
Skin and Language
Execution Stats
  • Time Now: May 18 2012 11:21 AM
