Im trying to put my motor back together but the guy who had it before me had a .010 basket on it. Im putting back together just the way it was but Im having a problem finding a base gasket. They make .012 base gasket but not to many .010. Wondering if anybody nw were I might be able to find one or if I'm gonna have to make one myself?
Page 1 of 1
base gaskets
#3
Posted 10 November 2011 - 07:40 AM
I'm with Bill. .002 isn't much difference.
Until the sand flies.....your just blowin smoke.
#4
Posted 10 November 2011 - 11:02 AM
I kinda figured that but wasn't 100% sure. Appreciatte the info tho guys.
#5
Posted 10 November 2011 - 03:05 PM
Keep in mind that the thickness of the gasket only matters when the cylinder is bolted on and the gasket squishes down. Some gaskets squish down more than others. I would take a squish measurement with the old setup then compare to the new setup. If you are really anal, then that is only way you will know for sure that you have an exact match.
With that said, I would just run the .012 gasket but I would check the squish with it just to make sure.
Just a little more hp and I should be set.
#6
Posted 10 November 2011 - 06:08 PM
i wouldnt even think twice about .002 difference. the +/- margin of error in the manufacturing process is probly almost that much
#7
Posted 31 December 2011 - 11:32 AM
and tha can be in each part. bearing, piston, pins, assembly etc..
unless i'm writing a BOOK and YOUR paying me i dont have to tell you nothin
Share this topic:
Page 1 of 1
Register Now!
Help
